My 95 Yamaha 250 was running at 5400 rpm at WOT and turned 44mph on a 24ft heavy WAC deep vee hull. I performed a decarb with Seafoam kreep (great stuff!) and when I took the boat out to test run she gained 200rpm and 2mph but now is running at 5600rpm at WOT and slightly above Yamaha's rated 5500 max. Should I re-prop with a size larger or not worry about it? Current prop is a stock Yamaha SS/black 17-T that I believe to be around 15inches in diameter. I would probably skip the 18 and go for a 19 pitch if I buy a new prop.
