Max HP for a OMC Cobra drive?
Bubba1235
No longer on Forums
Can anyone tell me where I would find the maximum horse power the OMC Cobra drive will handle. (1995 year)
Thanks so much
danond
Re: Max HP for a OMC Cobra drive?
Max HP as in "what happens if I install hop-up parts" or max HP as in "can I install a bigger engine"? Also, what model number on the drive?
bruceb58
That should be fine. You have the joint venture Volvo/OMC drive more than likely and that drive has been bolted up to big blocks.
If you have the raw water pump on the front of your engine, and not the drive, you have the "good" drive.
Limited-Time
Bubba.........your OD serial number is T0793419 ...............................Just don't ask me hoe I know.:mad::mad::mad:
a70eliminator
351's were stock on some Cobra drives, mine is a 351. 300HP @ the flywheel sounds about right, I wonder what the actual HP at the prop is.
bruceb58
Bubba must be the guy that beat you out of buying that boat from the other poster a couple weeks ago.
