i have a pair of 1992 merc carburated engines and my port engine is causing havoc. even at the dock when in fwd or reverse with full throttle my rpm is maxed out at 2200 rpm. replaced plugs/ carbs clean/ linkages set properly/ fuel is clean with proper 50 to 1 oil. 3 days ago it ran perfect through 5000 rpm under load and now only in neutral can i exceed 2200 rpm/ is there a black box i need to look at.<br /><br />thanks for any help
