Re: mating one piece rear main seal inplace of an old two piece engine OMC coupl
Oh, went back and read earlier post. You have a problem. The old bolt pattern is 3.58" and the new one is 3.00". Your coupler will not fit, as it bolts to the flywheel mounting holes. I' dont have a workaround idea off the top or my head. The only thing you might invgestiate is the fact that they made model 800 stringers untill '86 and the one piece rear main small block came out in '85 so you have a two year overlap there. I dont know if marine engines switched to one piece rear main as the same time, or if the model 800 coupler works on Electric shifts, but it gets you something to start with.<br />Jon
