Math Help
Reel Poor
I need to know the X demension from measurements of
11ft 6in x 17ft 7-9/16in.
rickdb1boat
Re: Math Help
21 feet 7/64 inch if it's 17' 7" X 11'6" Not good on the fraction...
EDIT: Should be 21 feet 17/32" at original proportions...
SlowlySinking
Master Chief Petty Officer
Re: Math Help
First convert the partial feet to fractions, then you'll need some high school trig to finish this up,,
rickdb1boat
Re: Math Help
Square foot is no problem. I assumed he wanted to know the diagonal distance... Oh well....
Bob_VT
Re: Math Help
Easy use the Pythagorean Theorem
Call the left side A
call the bottom B
Call the diagnal C
A x A + B x B = C x C
A squared plus B squared equals C squared
To take it a step further obtain the square root of C squared and you have the exact distance of the diagnal.
http://www.cut-the-knot.org/pythagoras/index.shtml
Bob
SlowlySinking
Re: Math Help
After I posted the text it had emoticons that replaced all closing parathenses, I wonder why???
SlowlySinking
Re: Math Help
Now the question mark was replaced by another emoticon,,, interesting since no emoticon is a question mark.
--GQ--
Re: Math Help
If your X dimension is two straight lines then the following is accurate to a tenth decimal place.
Angle Theorem; angle A=B=C=D and angle E=F=G=H=I=J=K=L, therefore segment W=X=Y=Z, thus segment W plus Z equal segment X plus Y.
W=126.295"
X=126.295"
Y=126.295"
Z=126.295"
(126.295+126.295)/12= 21.049 feet
W+Z=252.95" = 21 feet 7/16 inch X+Z= 21 feet 7/16 inch (rounded)
Reel Poor
Re: Math Help
:^:^:^:^ OMG....I'm glad I asked instead of trying to figure it out for myself.
Thanks guys
Re: Math Help
Why did you need to know? :^o:) 8)|O:D You should have asked the Scarecrow.
Edit: Hint; Wizard of OZ
