Master Power Switch on 2010 Q4 Tahoe
Status
Not open for further replies.
Charley24
I have no power to the master power switch on my 2010 Tahoe. Got to the lake and blowers wouldn't work. Turned on master power and then blowers and everything except ignition went dead. All fuses are okay. Seems there is no power to the switch from the battery. Any ideas?
alldodge
Relay need to know what motor and drive
Going to need a voltmeter. Can get a cheap one at wally world.
Start checking voltages from the battery, to the starter, then main engine breaker and continue on.
There is a 90amp fuse on the starter post if this is a Merc
Charley24
Would it go to the starter if it's the master power? Ignition and motor running fine. Just power to accessories. It's a 3.0 mercruiser I/O.
alldodge
Your talking about the master power switch, does it look something like this
Have you checked the battery cables?
Charley24
It is a toggle switch next to the ignition switch on the dash. It powers all of the accessories such as bilge, radio, nav lites, blower, and courtesy lites. All ignition is on separate circuit. The power switch was on and radio was playing when I stopped. Flipped up blower switch and all went dead. Boat still starts and runs fine. I checked all fuses and battery, but like I said, all was working except blowers, and then went dead.
alldodge
There has to be another fuse/breaker feeding the master switch. Either that of the switch it self is the breaker and may have gone bad. Take a volt meter and check for 12V
Charley24
Thanks, will do. I also found out that the blower is on a circuit by itself, not related to the Master Power switch. When the Master Power was on and I turned on the blowers is when everything except ignition went dead. Makes no sense.
midnight2
were you able to ever resolve you electrical problem.
I now have the same problem
any subjections.
thx
GA_Boater
any subjections.
thx
The OP made these couple of posts 2 years ago and never returned. Start your own thread for help.
Closed.
Status
