Master power switch lost power
TunTavern
While fishing yesterday my fish finder, nav lights, and courtesy lights quit working. My boat ('92 Bass Cat) features a master power switch which must be on for these accesories to work. It seems the master power switch is not getting power. I fished for about 4 hours with everything working fine. I had just ran the boat for about 30 minutes back to the dock. Pretty rough ride as there were a lot of skiers and such. I encountered the problem when I resumed fishing. Any suggestions on where to look first? Fuses? Connection knocked loose?
Jeremy Williams
Re: Master power switch lost power
I had the exact same thing happen to me last year. For me it was the fuse holder right at the battery. The inside had some corrosion. Took it apart and cleaned the contacts. Problem solved.
I hope your problem can be solved as simply!
TunTavern
Thanks! I'll start there and let you know what I found. Hopefully it's that simple.
TunTavern
Well...it turns out the positive terminal post running from the power switch to the distribution panel snapped clean off! Hopefully Bass Cat (O.E.M) has a replacement. Btw I didn't check the fuses b/c I don't know where they are.
seabob4
Look underneath your dash...
