Markings on Brass prop q's
twintrades
I just took a prop off a 40 hp jhonson i have and im trying to figure out what all the marks on it mean.
Inbetween the fins on the side it shows 247 m 7
On the tip it says Gan
A
smc
54
Thats looking down at it on the table
Otherwize GAN SMC 54 A
What the heck dos all that mean? Im just trying to figure out what prop would be good for tubing/skiing!!
Frank Acampora
Re: Markings on Brass prop q's
The "gan" is probably the last three letters of Michigan. The first ones were probably not stamped in deeply enough or were worn off.
SMC 54 A would be the numbers that define the model prop. And I believe that SMC is also Michigan terminology, reinforcing my thought that the prop is a Michigan.
Unfortunately bronze props are no longer made and the fellows here on the prop forum seem to have difficulty identifying them.
Try the Evinrude/Johnson forum or try finding the Michigan website where you might be able to get help from customer service. Only other help would possibly be on the old outboard site--don't know the exact address so you need to play a bit with Google.
twintrades
So no one could have a guess on what pitch the prop has??
