Mark 25 Carb. Float
tjhamms
I have a 1956 Mark 25. I pulled the carb. off to clean and I'm not sure how to check the float adjustment? If any. It looks like it rides up and down on the pin inside the bowl. (The float is not connected to the valve, it just rides up and down on the pin.) The float has a spring on the top that hits the valve closed when full. Is there any adjustment I can check for ? Thanks.
