I have a problem with the above engine. I am trying to connect my controls. The throttle control connects no problem. However the gear cable with clevis on doesn't reach the pin it needs to when the engine is neutral and the controls are in neutral. I have adjusted the cable as much as I can but it still doesn't reach. I have then investigated and believe that the slider on the shift bracket is not in the right place when in neutral. My question is can this position be adjusted. I have removed the carbs and taken a photo of the top of the shift rod, can the position of the bracket be adjusted. Also I have noticed an arrow on the bottom cowling right by the linkage as pictured. Does anyone know what this arrow means?
Thanks
Thanks
