1986 Mariner 60 EL SN#: ermell@att.net<br /><br />Disrewgard this posting. Have solved problem...<br /><br /> 675l 32866<br /> Will not go into reverse when motor is running. Further back movedment of the throttle increases engine speed When stopped and put in reverse detent and the fly-wheel is turned by hand, prop is turning reversed. <br /> Further back movement of throttle increase engine speed and grinding reverse gears is apparent and have been able to force it into reverse.<br /> My first motor and boat. ermell@att.net
