Mariner Identification
Treecatcher
I've just bought a boat with a Mariner outboard but I'm struggling to identify the engine. It's a two stroke, I'm guessing somewhere between 30 and 50hp, the Serial No. is either 06125254 or OG125254. The second digit is indistinct, the first digit looks like a zero and the rest of the numbers are clear.
Can anyone help with identification? I can add photos if that will help
Thanks
Treecatcher
I tried uploading a pic of the serial number and outboard but received a message saying I'm not authorised, any suggestions, is there another way of adding pics?
Alumarine
If you make a couple of more post you can upload pictures.
Just replying to this post will work.
Fun Times
Treecatcher
Thanks for the replies they have been very helpful, as soon as I am allowed I will try and post some images.
As far as I can see it is not a Mercruiser MC1 stern drive so I'm leaning towards the 1995 MARINER 30 MLH/ALT. Unfortunately I've not been able to find an image of one to confirm. Can you tell me what the MLH/ALT signifies?
Fun Times
Sorry if the info provided confused you some, it was more meant as general info had it been a 6 vs G.
M = Manual ROPE START
L = LONG SHAFT (20")
H = TILLER HANDLE STEERING
/ALT....I don't really know on the ALT designation but it won't stand for Alternator.
* MODEL TYPE CHART​
MROPE STARTPTPOWER TRIM
LLONG SHAFT (20")XLEXTRA LONG SHAFT (25")
EELECTRIC STARTC/RCOUNTER ROTATION
HTILLER HANDLE STEERINGEXLEXTRA ETRA LONG SHAFT (30")
OOIL INJECTIONOSOFFSHORE MODEL
Short & LongBOTH SHORT & LONG MODELSEFIFUEL INJECTION
TRTRACKER DECALSTRMMTRACKER by MERCURY DECALS
4-S4 STROKEBELBELGIAN-MADE for US MARKET
C/RCOUNTER ROTATION
The below info should help with better terminology of stern drive vs outboard, etc..
http://forums.iboats.com/forum/engi...-safe-search-version-of?p=4138463#post4138463
attachment.php
Treecatcher
No Title
Ah now for some pics
Treecatcher
Thanks to Fun Times for all the info as you can see I'm a bit of a novice at this.
A couple of points on the MLH designation.
It does have a pull start but also an electric start, I guess this could have been added?
I'm not sure about the length of the shaft, can you tell from my pics?
It is not a tiller steer, could this also have been a modification?
It is a two stroke and looks very much like the one in the is advert,
https://www.smalloutboards.com/mar3098.htm
Except it doesn't have any indication of Hp rating on the cowl or engine and the decal is different
Thanks again for your help
