Hey folks,
I just joined the forum, read a few posts here and I have to say that as usual on these forums, we have some pretty knowledgeable people on here. Thanks for being here.
I have a question about the outboard motor on my pontoon. It's a 1989 90 hp Mariner and it has given me pretty good service. But this past summer, I noticed that when I power up on it, the RPM's will go up, but (without a tach) I can tell it's not running to full potential.
If I run it about 3/4 throttle (or even full throttle for that matter), it will go like that for a while, then it's like something "breaks through" and it powers on up the way it should. As long as I leave it up there it runs at full strength, but if I back it down, then power up again, it will go back to running at the reduced rpm's until it decides it wants to run at full strength again.
There's no set pattern to this either. It's kind of hit and miss.
My first instinct is that it's a carb problem, but I am by no means an outboard mechanic. I have not tried running any Seafoam or equivalent through it yet, but I'm thinking of trying that first.
Any suggestions from y'all would be most appreciated.
Thanks,
Kris
Thanks,
Kris
