Mariner 8HP year? nothing on plate
ukharper
Hi, just got a Mariner 8hp(at least that is what is on the cowl) but the plate is unreadable. I have 306108 on the block though &
the Carb has 6GL10WC02 (or could be 6G110WC02, it`s a 2 cylinder long shaft with CDI ignition & looking on here I think it could be 1983.
Also what would be the spark plug gap on this, the old plugs are NGK B7HS. I`ve set them at 0.6mm at the moment.
Where would I get the remote throttle linkage from?
After stripping & putting the carb back I got it running sweet but the telltale only produces a vapour instead of a stream- does this model have a thermostat which could be clogged with salt?
Thanks in advance
bilge rat jim
Re: Mariner 8H Pyear nothing on plate but
Where did you find the 306xxx number? Can you post a cupla photos, one of the outboard and one of the starboard side of the block?
ukharper
Re: Mariner 8HP year? nothing on plate
OK, the 306108 number is on the block above the sparkplugs. The tiller was kaput so I am after sourcing the remote throttle linkage?
Cheers
bilge rat jim
Sorry, I can't find that number anywhere, either as a serial# or a part#. I can tell you your outboard is pre-1988.
carholme
Shot in the dark here but the 6G1 number on the carb helps and with the number you provided in your first post, it could be:
8C ML 6G1-305951 - 6G1-309573 1984
From here:
Mariner 2 - 8 hp, produktions?rslista, modellguide
These are Yamaha built engines for Mariner.
Here is another discussion on iboats:
http://forums.iboats.com/mercury-mariner-outboards/1984-mariner-cracked-carburetor-parts-568944.html
8C is a Yamaha designation and The ML is for manual start, long shaft.
Parts List:
6/8 H.P. - Mercury, Mercruiser, Force, etc. Parts Lookup
Is the sparkplug NGK B7HS or NGK B7HS-10 as Yamaha calls 4/5hp for the HS and 6/8hp for the HS-10
Gerry
ukharper
I`ve got B7HS in it & it is running ok, what difference would B7HS-10 make as these are suggested for the CDI ignition so do I need to swap?
carholme
Well, as I posted above, Yamaha calls for the HS-10 and if you look at the parts list in post # 5, item 18 under CRANKCASE AND CYLINDER HEAD, you will see that calls For HS-10 as well.
If you look at the 8C 6G1 series in this NGK link, you will see that they call for HS-10:
http://www.ngksparkplugs.ca/results...ginesize=8.0+hp&make=MARINER&apptype=Outboard
Have you looked around the engine block to see if you can find a disc like this:
http://imageshack.us/a/img84/8224/391496208.jpg
If so, that will be the s/n.
Gerry
ukharper
Local dealer said the correct plugs are in, regapped the to 1mm & it starts easier.
I am still only getting steam from the telltale even though I changed the impeller. I put a hose on water tube in the leg & it came out the telltale, I also held the lower drive in water whilst turning the driveshaft with a drill, water coming out of the pump top as expected although not a strong squirting mind, any ideas?
