Mariner 8hp lose power on full throttle
Superflid
It's been a while since I was here, but to see the news that "You last visited: December 31st, 1969" was a surprise!
I'm sure I've been here since then!!!
Anyway....
Mariner 8hp, starts first or second pull every time. Ticks over fine, runs up to about a third or half throttle OK. Wind the throttle open and she roars away for a couple of seconds before coughing and struggling to keep running, close the throttle to half or less and she picks up and runs fine again.
Looks to me like fuel starvation...
Cleaned carb, checked filter, changed plugs, still the same.
Serial numbers are 6G1 S 018937
Second question.
There are 2 green wires coming from the motor that are not connected to anything. Are these from a charging coil?
Thanks in advance for any tips.
Don S
Re: Mariner 8hp lose power on full throttle
When the forum went to new software some months back, everyones started off saying that. After the first post, it moved on............. as yours did.
Sounds like lack of fuel is your problem. Might try squeezing the fuel bulb when it starts sputtering, and see if it picks up. Fuel pump may be week.
Superflid
Thanks Don, I'll give the bulb a squeeze next time, should get to the boat before the end of the week.
Anyone know about the wiring?
Superflid
Tried and failed!
Pumping bulb made no difference.
Carb has been stripped and cleaned, so has fuel pump.
Could it be an ignition problem? Timing or points? It does start easily and run up to half throttle OK though.......
bgbass.1
sounds like its running lean when you pull the choke it richings up the mixture. I would do a link and sinc and see if it helps
Don S
Probably time to pull the carb apart and check for dirt and/or water. The hi speed jet may be plugged up.
Superflid
Call me dumb, but what's a link and sinc?
