bluenoseboater
- Sep 21, 2010
- 13
Hi there,
I am wondering if my 1982 Mariner 70 hp, 3-cyl, S/N 6228858 has a thermostat and/or poppit valves? When connected to the earmuffs, I ran it several minutes and got no stream from the tell-tale. The engine seemed to be getting pretty hot so I shut it down.
When running, there was a significant amount of hot water leaking out between the upper drive shaft housing and the lower gear housing. I removed the lower unit and discovered there is no gasket here. I have read in some posts that it is not unusual to see some leakage at this joint but excessive leakage may mean a problem with the water tube not being seated properly, or obstructed.
I disassembled the water pump and found one vane missing. The rest are intact. I ordered a complete water pump kit which I plan to install as soon as I get it. Before reassembly, I am wondering a few things:
1) Where did the missing vane go? Could it be lodged somewhere in the cooling system and causing an obstruction?
2) Does this engine have a thermostat and if so, where is it located? If it has one, I'd like to remove it and test it.
3) Where is the poppit valve(s) located? Should I be looking at this?
Any help much appreciated. I want to be sure my cooling system is up to snuff before starting the season.
Thanks,
Wade
Thanks,
Wade
