mariner 60hp 3 cylinder 2 stroke
weejohn
i purchased a mariner 60hp a few weeks back . i have done full gasket kit on twin carbs / on fuel pump and changed the fuel filter and renewed water pump the compression on all 3 cylinders are 125 psi and i have good spark .when i put the starter motor back on i went to start it by a jump start i have a fault on my controller cable so i disconnected it until i sorted all the problem , what is happening is the starter is going very slow it hardly turns it over . the battery is fully charged all connections are are clean i used wet and dry paper on them . the starter is smoking and the starter is hot to touch . is it the solenoid or do i need a new starter ? all help would be appreciated :)
Faztbullet
Re: mariner 60hp 3 cylinder 2 stroke
Either starter brushes or bad ground to starter...
weejohn
i opened the starter and stretched the springs so the carbon brushes would last a little longer . when i have the starter of the engine it spins as it should . The earth is fine rubbed it down so it had a good contact
weejohn
when i take the spark plugs out it turns the engine over fine i put the plugs back in it turns slow because of the compression of the cylinders so it looks like the starter ? any thoughts before i buy one just in case it could be something else .
Faztbullet
Starter is bad.. needs new brushes or armature has throw solder and not making connections
Faztbullet
Starter is bad. Itneeds new brushes or armature has thrown solder.
weejohn
thanks so a new starter motor it is
weejohn
i got a new starter and it runs fine the only problem i cant get the engine to fire up .compression good so is spark and fuel is fresh i am doing the choke by hand , i have to jump it the controller has a fault any ideas so i unplugged it
