Hi One and all,
I have a 50hp 1990 mariner and am having trouble. I have fitted out boat with switch panel, new nav lights, sounder, radio,cabin led's. I had to change the wiring config behind dash as the already existing wiring was older then myself. in doing this i was trying to rewire tacho to forward control and have some how managed to short out controls or motor. i have done continuity test's on the following components, Kill switch (ok), ignition (replaced with new last night), neutral switch (ok), i have tested all relays and fuses on the powerhead, for some reason i am getting nothing when i turn the ignition on. The power head is receiving 12.2volts no worries at all. i have completed continuity test on all ignition components on powerhead also. if anyone has any ideas suggestions please let me know. i am at the stage of bypassing the tilt/trim to raise motor for transport and taking out to auto electrician.
cheers
cheers
