stan_deezy
- Oct 18, 2003
- 1,539
Please, please, please help a balding man (I'm ripping my hair out!)<br /><br />Mariner Magnum 4Cylinder 2 stroke oil injection model 1990 vintage.<br /><br />Just sold the boat, engine trailer package and am due to deliver it in the next 24 hours.<br /><br />Engine well maintained and regularly serviced. Ran one month ago as part of it's routine whilst lying ashore: no problems with it at all at that time. <br /><br />Filled up the test tank this morning and wanted to run the engine to check that I wasn't selling a lemon and it won't start!<br /><br />New fuel in tank, primer bulb going firm on pumping, new spark plugs fitted just in case, 20 amp fuse replaced, just in case there was high resistance but all to no avail.<br /><br />Electric choke is working, no settings have been altered, everything is as it should be.<br /><br />The only thing that I can recall happening after last run is that I swapped to a new (good, known) battery and reversed the polarity by mistake. I knew instantly that I'd done it and the engine wasn't started, the key wasn't turned etc, so I would suspect that no damage could have been done......or could it?<br /><br />I'm working alone so if anyone has advice on how to check for a spark whilst standing five feet from the keys or the engine I'd be grateful....<br /><br />Any help or suggestions gratefully received.<br /><br />Finally just a quick question: If you were buying a boat and the seller phoned and said; "I can't get the engine started so I'm having to delay delivery until a workshop can look at it and sort out the problem" would you be happy or angry and would you withdraw from the sale?
