Mariner 25hp, 50:1, forgot oil.
sammymcnally
I know how stupid this was, but there was a quarter tank 50:1 and I filled the 5litre can with straight unleaded. I ran it for 6 miles and it stopped. In neutral it's pumping water, and did turn over and re start, but as soon as gear was engaged it stopped. I assume I have wrecked it, but if I take out the spark plug and put some oil (or anything else??) in it, will it stand a chance? There was a crunching noise when gear engaged. Makes me think the cylinders are shot. Again, I realise what a dope I have been. But all advice gratefully received. Thanks. It's an old mariner 2 stroke, approx ten years old.
sammymcnally
Should have also said that the pull cord still works and pulls out ok. I had assumed that seizure would have prevented that, but I know very little about outboard engines to be honest.
tpenfield
:welcome: to iBoats . . .
Oil in the cylinders and into the intake would be good to get some oil back in the engine. Compression test would be a good next step. That should tell you something about the condition of the engine.
sammymcnally
Thanks both. I took out the plugs and put in some Valve spray, then poured in some oil and then gently pulled it through. It works a treat now. Really appreciate your advice, some relief! There was also a green wire on top of the engine which had become disconnected. There are two green wires actually - but only one had come off. I'm starting to wonder if that was the problem... Thanks again Ted and FlyingScott.
ajgraz
The green wires are likely switch box to ignition coil, one or both of those being loose could cause the stall under load.
jimmbo
If there is damage, oil is not going to repair it. I would pull the exhaust cover off and look at the piston skirts for signs of scuffing/scoring. The bearings for the crankshaft, connecting rods, and piston pin are all roller, ball or needle, but still may have been damaged, but only a teardown may reveal that.
What speed did you run the engine at for the 6 miles? There was some oil in the gas, if thoroughly mixed it would have been about 200:1. Unless you shook the tank as you added gas I doubt the fuel was completely mixed and a slight richer mix remained at the bottom of the tank.
