Hi
I bought a 25 HP Mariner from 1982 (25E, model: 695) a year ago as a spare engine.
The seller said that it run bad and that is has low comp one cylinder.
I did a dry compression test on the sparkplugs and both cylinder gave me about 50psi.
With a bit of oil in the cylinders this bumped up to about 105 to 111 psi, fairly OK.
I've found out that this i most likly because of a bad piston rings.
Im now thinking about taking of of the headcylinder to check if its a broken piston ring och or a bad cylinder.
Any thoughts what it might be?
Also, If I need to change the piston rings... Do I need to change all the gaskets for the cylinder?
A long, long time since i've changed piston rings and gaskets on a engine...Don't remember much... All answers are welcomed!
