mariner 1988 60 hp 3 cylinder 2 stroke
weejohn
i have a question about a mariner 1988 60 hp 3 cylinder 2 stroke i have Choke Solenoid and beside it their is a manual pull choke the choke solenoid heats up it cant pull open the choke it has no cables attached to the carb ? it used to click now it does not . i had it of the engine and attached it to a battery it heats up fine but no click . my manual choke is attached to the carb and that works fine .what is the purpose of the electric solenoid and would it stop my engine from starting if it was faulty
ajgraz
Re: mariner 1988 60 hp 3 cylinder 2 stroke
Manual choke pull is attached by a wire/cable to a plastic bar that spans between the two carbs, when you pull upwards it simultaneously closes the choke valves on both carbs. The electric choke is a metal cylinder which is withdrawn/pulled upwards electromagnetically right into the solenoid's chamber, and that cylinder is attached to the same plastic bar with a thin plastic arm.
(That thin plastic arm from the electric choke cylinder to the plastic bar is extremely wimpy and likes to break, check on that)
If manual choke works, but your electric choke is not opening (not even "clicking"), and you are sure power is getting to it, then my guess is that either the solenoid has gone bad, or there is some gunk inside the solenoid chamber preventing the cylinder from smoothly withdrawing inside. Or perhaps that thin plastic arm I mentioned has broken, and the cylinder has fallen out of the solenoid.
If the solenoid/electric choke mechanism has gone bad, that would not prevent your motor from starting per se...it would make it more difficult to start cold of course just as if if you had no choke (control).
weejohn
the electric choke has 2 wires .when you turn it upside down at the bottom is a hole in is a cone like shape that's it no plastic thing which attaches to the carb .looks like i need a new one or i need to take the hood of to use the manual choke
weejohn
thanks for the help i found the cylinder that goes in it thanks it fine now
