Re: mariner 1988 60 hp 3 cylinder 2 stroke
You mention compression and spark but don't say whether or not you are getting fuel. Does the bulb pump up and remain firm? Have you pulled a plug to see if it is wet? Alternatively, Pull the line going to the carbs and with a drain can, crank the engine and see if you get a good pulsating fuel flow.
Gerry
