greene1564
- Jul 23, 2015
- 1
I bought a 1984 Randall Craft 14' boat, it has a Mariner 15 HP outboard on it. The engine had been running well except for the spark plug wires have been sliding off the plugs. Today I changed both plugs and slid on the wires and they fit tight on the new plugs. I took the boat out and the engine ran better than it has before, I was impressed until all of a sudden at full throttle the engine quickly bogged down and died as if some cut off the fuel. I pulled the cover off and the plug wire was off the plug. I replaced wire and was not able to get the engine to start back. It will fire for a second then die. I replaced the wire boot assembly on both wires because they fell apart when I pulled on them. I thought this should fix the problem, however no the same thing. I am getting fuel to the Carb and fire to the plugs. I do not know if it is just flooded and unable to restart. I pulled both plugs and I am going to let it sit until I get home from work tomorrow to see if this works. any other suggestions would be appreciated. the engine is a Mariner 15M 684 C 026169. Thanks for any help
