Marine water circulation pump vs. Automotive
dlogvine
Master Chief Petty Officer
I'm looking to buy a water circulating pump for 2002 mercruiser 4.3 v6. Looks like an automotive pump is the same as the marine version and at least $40 cheaper. I cant think of any significant differences that could make a regular chevy pump unusable in marine application. Or am I wrong? Can paint the pump with anticorrosion paint. Thx
achris
More fish than mountain goat
Automotive - Impeller is pressed tin, seal is steel, backing plate is steel.
Marine - Impeller is cast brass (and bi-directional), seal is stainless, backing plate is stainless...
Apart from that, yes they are the same ;)
Chris......
wellcraft-classic210
Hi
I believe the parts inside the pump ( fins on the impeller ) have added corrosion resistance to hold up on open loop cooling systems with no antifreeze or corrosion inhibitors present
The experts may be able to elaborate.
if you have a heat exchanger, it doesnt matter. however if you are raw water cooled, see Chris's comment....you need a marine pump
Lou C
Don't get into thinking that automotive parts will work in a boat, that is a recipe for disaster! Marine carbs, alternators starters and distributors are all different for safety reasons. An auto pump in a raw water marine application will fail in short order leaving you stranded.
aimlow
This. Plus, some pumps spin the opposite direction on a SBC. Marine pump has straight impeller blades and worh either direction.
