Hey guys. I'm a marine tech working on a personal motor. Finished school not too long ago, so I am a fairly new tech, not new to motors. Got a problem that I need help with so I'll give it a try here.....
1993 Johnson 40 (tracker) (converted to premix)
Compression: 140, 140
Good blue spark
Both carbs recently cleaned, properly adjusted
new fuel lines
new tank
new ign coil (tested bad)
sync and linked
VRO2 was bypassed with new fuel pump/ lines
problem: Engine will not idle
What I have done: Set idle mix screws all the way from very lean to very rich, while advancing timing through all ranges. i even maxed out the idle timing stop screw. Idle timing can be fully advanced as far as screw will allow and idle mix screws through all ranges will not idle engine.
Engine will idle with warm up lever almost fully up. All adjustments have been made on the stand with muffs with no back pressure so this is even more confusing because it should idle even higher with no back pressure.
Let me know what ya got. This is not the first time I have seen issues with the 40, 48, 50 idling, but never to this degree....
Good blue spark
new fuel lines
new tank
sync and linked
