I was looking for something else and stumbled on this site.
I've included a few questions and answers also.
Comments or thoughts about it?
3/4" Marine Grade Plywood
Marine Grade Pontoon Plywood
$95.00
https://www.pontoonstuff.com/collec...et-flooring/products/3-4-marine-grade-plywood
Choose between 8' and 8-1/2' long CCA treated marine grade plywood.
This CCA treated marine grade plywood has a B face and C bottom. The top is sanded smooth but may have small knots and the bottom will have unfilled voids. This does not affect the durability of the plywood, it just may not look as nice as you expect. These superficial blemishes will not affect the lifetime warranty on the plywood, it will be covered by carpet.
CCA treated plywood does not need to be coated or treated before installation and has 7 plys that have been pressed and glued together then kiln dried, it will not warp or rot.
This plywood is distributed through Huttig Corporation and is the same plywood used on all 2014 Bennington and South Bay pontoon boats.
Q - Pressure treated plywood can react negatively with aluminum cross braces found on toons. Is the CCA treated plywood you sell safe to be in contact with aluminum without fear of corrosion?
A - Yes, there will not be any worry using this CCA treated plywood with the Aluminum cross members.
Q - Is the glue used between the layers waterproof and I'm just confirming that the bottom (that faces the water) does not have to be sealed.
A - Nope, nothing on the plywood will need to be sealed with anything. Ready to use, right away.
Q - What kind of wood is used to create this plywood?
A - We use Douglas Fir for the plywood.
$95.00
