Re: Marine Manifolds: How do they Work?
There are two main principles:<br /><br />The motor exhausts, just like any car, into the manifold. Well away from the exhaust ports, behind a bend to make sure water does not get near the ports, the 'used' water is pumped into the manifold. The exhaust/water mix is then lead outside the boat - either via the outdrive (if any) or via some kind of waterlock and/or silencer.<br /><br />A crack in the manifold will, in almost all cases, result in water inside the motor compartment.<br /><br />If the system is with heat exchanger, it's just like a car ('dry' exhaust). In this case, the hot coolant is lead to a heat exchanger, where seawater is used to cool down the coolant before it's circulated back to the engine. Seawater never gets near the engine - only passes through the exchanger (which is made from alloy or alike that withstands the saltwater). <br /><br />Big difference is, that when seawater (saltwater) is allowed in the engine coolant channels it corrodes everything. Especially when getting hot (which is why, by the way, those engines often run at what seems to be a very low temp.). As exhaust is very hot from the combustion and gets mixed with the hot water in the manifold, those (often cast iron) manifolds tends to corrode before the engine. Next part to corrode is the head.<br /><br />When using a heat exchanger, the only thing inside the engine cooling channels is coolant. This prevents corrosion, lubes water pump and contains antifreeze.<br /><br />Systems designed for seawater cooling definately works best when used in freshwater as is not as agressive to the engine parts as saltwater.<br /><br />Add to this, that boats that are trailered/lifted out of the water, drains the seawater from the system (engine or exchanger) thus greatly reducing the risc of corrosion.<br /><br />Check
www.vetus.com - they have a lot of good parts and pics. on the subject.
