Marine grease OR anti-sieze grease ?
chris turner
What do you experts think is the best way of helping to prevent parts siezing up ? EG - the propshaft bearing carrier (Honda 9.9) - both the bolts and the actual carrier outside edges ?
JustJason
Re: Marine grease OR anti-sieze grease ?
Mercury 24C marine grease
For fasteners I coat bolt threads with Permatex Super "300" Form-A-Gasket Sealant, Item #80057, 83H. The stinky brown material coats the threads to a tarry consistency, preventing rust and keeping the fasteners from vibrating loose.
http://www.permatex.com/products/Au.../Permatex_Super_300_Form-A-Gasket_Sealant.htm
It was recommended by my mechanic for everything but torque critical fasteners, like head bolts. For those he recommends the proper Loctite formulation for the application.
http://www.loctiteproducts.com/threadlockers.shtml
I use Amsoil Water Resistant Grease in my jet unit, wheel bearings, and all of the grease zerks.
http://www.amsoil.com/storefront/gwr.aspx
Don't expect greased fasteners to remain fastened due to vibration.
