Re: Marine Engine Rebuilder in Canada
Hey capt. Any good engine shop should be able to fix you up. there is not much difference between a marine engine and a truck engine, but those differences are important. (cam, freeze plugs, gasket set, block drains, etc. to mention a few). you can reuse all the bolt on stuff like the alternator, water pump, fuel pump etc. although I would probably get a new fuel pump if it were me, if the existing one is 20 years old..good luck
