I have a strange question for you guys, but here it is.
As some of you already know, I'm an importer of CNG conversion kits (to convert cars to run on natural gas). I've been wanting to experiment with a natural gas conversion on my boat.
First of all, I know it's not "marine approved", but I'm hoping to develop a system, and GET IT APPROVED. Gotta start somewhere, so please no lectures.
The system will be properly ventiliated, and there will be no electronic components in the engine compartment...
Anyway, with all the disclaimers out of the way, I'm looking for a marine ignition system that utilizes a MAP sensor to calculate timing advance.
The reason is that in order for the boat to run optimally on CNG, the timing must be significantly advanced, over a regular gasoline setup. This is because CNG has an octane rating of around 130.
Now, obviously, I don't want to have to get out my timing gun and turn my distributor every time I switch between fuels.
There is a module for CNG systems, which will modify a MAP/MAF sensor, signal so that the ignition will believe that the engine is at higher RPM, and advance the timing automatically. So when you flip the switch to go to CNG, the voltage level on the MAP automatically changes, and the ignition advances timing. Make sense?
Alternately, it can install a module which uses a crankshaft position sensor, but my engine doesn't have one of those either, and it wouldn't make sense to go to the trouble of trying to add one, since a map sensor would do as well, and be MUCH easier to install..
So I'm looking for a marine ignition system that will utilize a MAP sensor, so that I can install the CNG module to automatically modify timing advance, at the flip of a switch.
I really don't know anything about aftermarket ignition systems, and since virtually every modern car uses a MAF/MAP, this is the first time I've had to try and figure out how to add one.
Naurally, my points ignition on my carbed 1981 engine setup isn't going to have what I need on it. For now, I can time it manually, but since I'm trying to develop something that the Average Joe can easily use, I need to make the switching between fuels as seamless of a transition as possible (literally the flip of a switch).
