Re: Marine CB radios
being from australia too, I can confirm that we use 27MHz AM CB's for marine applications. However, in australia and new zealand, the marine frequencies used ARE a bit different from the standard car/4wd AM CB frequencies - even though both are in the 27MHz spectrum. If you use the car type CB's here, they will not me monitored by the local sea rescue groups, but as Frank said - they are quite cheap so its not a big expense to have one. You really need to check the RF spectrum standards in your local area though.<br /><br />Frank - I presume your $50 has been converted to US$ ?. Do you have an email address I could contact you on? I may be in the market for an new marine radio soon - so id like to pick your brains about cheap places to buy.<br /><br />Cheers<br />Troy
