I have a 1989 Johnson Outboard Motor with a manual tilt on my Lowe 16' bassboat and the motor will not lock in place in any position. It is a 40 hp J40ELCEC motor. This presents a problem when I put the motor in reverse as the motor raises up and the prop tries to come out of the water. From the lock lever there is a cable that runs to the top of an actuator. I am not sure how it works. When I lift the motor or let it down there is still a dampening effect from the actuator. I am new to boating but can fix minor problems. Any assistance would be greatly appreciated. I have no maintenance/owners manual as I bought the boat used. Thank You....
