jdstephwacotx
- Aug 16, 2004
- 53
I'm not really familiar with tilt and trim other than the following:<br /><br /> 1. Tilt is the button on the throttle that allows you to lift the motor for trailering.<br /><br /> 2. Trim is what you adjust while driving to get optimum plane.<br /><br />If either of these is incorrect please correct me.<br /><br /><br />Now for my question.................<br /><br />My boat has neither. It is an old 1960 Larson runabout with a 76 85HP Merc. I have other motor problems that are being addressed in a separate post.<br /><br />This motor has a set of tabs that get rotated into place in order to keep the motor up for trailering. I believe that this is what would be considered 'tilt'. There is a bolt and a series of holes on the transom that I assume is some sort of manual trim. Until I get the motor running well I figured there wasn't any reason to mess with these. But last night I noticed that there is a clamp that 'grabs' that pin on the motor side and attached to this clamp is a pin that goes down into the lower unitl above hub/prop area?<br /><br />If I manually pull the clamp down like I assume it should do when it is against the pin, it pulls this pin in the lower unit upwards.<br /><br />What is this for? If it is not engaging and not pulling the pin upwards what isn't happening that should be? It almost seems like some sort of safety cut off or something.<br /><br />If there is no tilt motor, what are the two pistons on either side of the motor for? Should they assist and make manually lifting the motor less heavy? If so, they are shot. What kind of money are we talking to replace them?<br /><br />Thanks for any input that you may have.
