Re: Manual tilt question
Unless you have it locked down, any outboard will try to tilt up and ride over something if you hit it unless you have the little reverse lock latched.<br /><br />Most tiller steer or non hyd. tilt engines have a catch on them so the engine won't climb up or tilt when you back up. Just make sure its not latched when you are in FWD. <br /><br />If the engine can't tilt up when it needs to,,,,, it can get real exciting sometimes.
