I have a problem with the manual starter on 9.8HP Mercury 110 - when the temp is below freezing point, the starter won't rewind the rope. Can I use WD-40 on the sheave shaft or some special grease should be used?
Also, any advise on winter cold start procedure? In summer the engine would start after a few pulls, but when the temp goes down it becomes tricky. Thanks.
