5.7L MCM260, I'm only pulling about 10 ~ 12 inches of vacuum at the port in the top of the manifold. The manual says 18~20 is normal. I have leak tested with Propane and WD40 and can't find anything. I also checked that the manifold bolts are torqued at 30lbs. Any suggestions on what to look for? Also, there are two threaded holes on the left (port?) side of the manifold that have nothing in them (see attached). What are they for and could they be leaking? Thanks for any help/suggestions.
