Re: Mando alternator
Generally, the higher the alternator output, the higher the cut-in RPM. Most alternators will cut in below 1000 RPM. A ratio of at least 2:1 off the crank pulley is needed, you apparently have a higher ratio already. How many amps is the Mando vs. the original Delco? With your cut in speed I would expect a 100 + amp unit.
