Man I screwed up ...
naolssloan
I just picked up a sea king 5H I think it was made in 76 . Anyhow took the boat out and she worked fine and I turned it off for a bit just to drift and then when I turned it back on it was in nuetral but it was idling high and I put it into gear without taking the idle down and It made a noise and well .... lets just say thank God for ores . Engine hums right along but boat does not go. I know alot about car , motorcycles , lawn mowers but have never messed with boat motors . Anyone thank they can steer me in the right direction ? The model # is K5504106 A the serial is 1250371 .
tinlizzie
Re: Man I screwed up ...
pull the gear housing off and take a look. bad deal more than likely.
naolssloan
I just removed the cotter pin and pulled the prop off and there was a small rod that fell out that was in 3 pieces ( that was inside the prop ) . Is that the pin you guys were talking about ? If so how do I go about replacing it ? Can I just take the prop in and they can just match that to the pin size ? Or do I have to have the make and model for it ? I have the serial and model in the first post but have no idea what year it is. Boy Im glad its just a pin ;) ( do people shear pins all the time ? ) Thanks -- I called a local shop and they said its and old montgomery ward motor and dont have a pin for me. Where on earth would you go to find something that old ?
steelespike
Motor was built by Clinton out of business since the 80s uses a 5/32 X 1 3/16
brass pin.you just had a typical Clinton outing.Seldom run the same way twice.Hopefully with some tinkering it will perform for you.
naolssloan
Thank you very much ...
robert graham
go to the hardware store like Ace, Lowes, Home Depot and buy a section of an 1/8" or 3/6" brass rod and cut(with a hacksaw) a bunch of those shear pins and keep them in the boat for future use. those pins really protect the motor from damage when/if you hit a log or a stump. easy fix! Good Luck!
