roustabout
- Jul 5, 2007
- 2
Hi,
I was wondering if you had any information on any other Mako 212 CC sinking? I purchased a new 2004 model in 2005 and kept it in the water at my home dock here in Savannah, Ga on a protected creek. I had taken the boat out 3 days prior and all systems were fine. We had a rain storm with winds all day on June 2, 2007. I checked the boat before leaving for work and all was fine that morning. I received a call from my neighbor around 8:30 pm that night to inform me that my boat had sunk. I returned home to find her still moored portside to my dock and her starboard submerged at approx 180 degrees. I was informed by my insurance co. that the surveyor has determined that the splash well could not drain properly because the engine bracket blocks the drain. The control cables enter the inner hull inside the splash well and it seems that the entry location is not water tight allowing water to flow into the inner hull. The floor drains do not drain above the water line but instead drain below through rubber scuppers. I question how water from an interior drain can over come the pressure from the water surrounding the boats exterior? But then I am not an engineer. I have only found a few manufactures that install deck drains which discharge above the water line in this size boat. I visited the local Mako dealer,(Tracker Marine @ Bass Pro) where I purchased the boat and discovered that a new 212 boat on the lot had a splash well half full of water, I assume the rest drained into the inner hull through the cable entry point. It had rained earlier that same day. I will be contacting Mako about this after I have received more settlement information from my insurance co.(USAA). I cannot understand why a manufacture charges over $40,000.00 for a boat that cannot even drain water properly on a trailer! I would appreciate any information you may have and my hats off to Tow Boat Capt. Dana Rutland, he and Bubba,( the other Capt.) worked in pouring rain and wind to raise my boat and tow it back to the marina.
Thanks,
David
Thanks,
David
