Re: Make your own gaskets
i have made a fair few gaskets since my teenage years on most engines except head gaskets ( always use new for heads).
i like the empty shell cases idea!
the perspex and sheet of wood & drill technique, a i recall learning off a wise master fixer of anything mechanical many years ago and is a very good tip
i think hands on heart,many of us has at some point made a gasket out of cereal cartons,shoe boxes etc for carb,engine casings and the like
one tip when making a gasket from card is to wipe a thin smear of grease on one of the mating surfaces and press the card gently down whilst keeping the card still and with a free hand,gently dab the card all the way aroung the surface of the joint.
pull up in one quick motion and there is your imprint of the exact gasket and holes to be cut out.
another tip when using homemade gaskets is to smear a thin film of grease on the gasket.
this serves to keep the gasket in position and when the joints are bolted together,allows any slight adjustment of the gasket to the bolt holes.
it is down to personal preferance on the grease as most new people will fit gaskets clean and dry.... i was taught 31 years ago by a sadly missed mechanic who was in his 50's and gave me the fix it attitude to most things.
not so far of the big 50 myself now
practice on card 1st as mistakes can be made and the genuine gasket grade papers are fairly expensive.well in the UK anyway.
good luck
