Just bought a boat and trailer that I am picking up tomorrow. My first
. Here is the problem. The trailer has a broken leaf spring hanger. Currently, the front of the spring is being held to the trailer with the pin and a weld on one side only. The other side broke off at the weld. Guy says he's driven it like that for over a year. I can only imagine the stress the hanger and bolt are under. I have a replacement hanger and someone to weld it. Can I use a square bolt with some type of bar across it as an emergency fix til I can tow it to the welder? It's going to have to go with the boat and motor on it. I'm going to have the welder check the other welds and I'm thinking I should just replace the springs on it while I'm at. If anyone has any suggestions, I would appreciate it.
