Today:
Had a great day out on Lake Jesup - Orlando FL. (Caught 16 speckled pearch before the cold front moved in).
Have a 1987 25hp Mariner. On the way out, every time I would attempt WOT it would sound like the prop was out of the water spinning and experienced major loss of power (which was not the case, I never had cavitation problems). Every time this happened throttled down a bit and we were fine. So I kept it just under WOT the rest of the day. On the way back we ran into some sand in the shallows, no problem tilted the motor got off the sandbar and cruised just under WOT all the way back until about 200 yards from the ramp the power died and couldn't get the boat above trolling or idle speed. The pressure and combustion all seems to be fine. It starts, rev's up and idles fine. Luckily this happend on the way back very close to the ramp.
What could this problem be? It's got to be some kind of pin or maybe a gear that's come loose... not sure never had this problem.
Any help would be appreciated. Thanks all!
