Wet Wonder
- Jul 18, 2008
- 72
I'm going through the fuel system from the pump backwards to the tank, checking for leaks, checking fittings, vacuum from the pump, etc. The manual suggests, during fuel system maintenance, to take the mechanical fuel pump apart to inspect and clean, and to replace failing parts as needed.
Is disassembling the mech fuel pump something that folks tackle? Or do folks prefer to just swap out the entire pump if they have suspicions about it?
