i have a BIG 30hp mercury, serial og059280, i think its 645cc or something.<br /><br />Having searched the net, it seems that these models are the excact same enigne as the 40hp 1994 model 645cc, can this be right??<br /><br />The only difference i can find in searching part-schemes is that the 30hp have a 0.54mm main fuel jet, and the 40hp has 0.66mm.<br /><br />Can it be this easy?? will my 30hp engine run like a 40hp if i change the fuel jet in the carb??<br /><br />If this is right, are there any other changes or adjustments i have to do??<br /><br />The serial number range my outboard is within,is the same for the 30 and 40hp models. on the timing marks inside the engine, it states 30/40, i guess this means 30/40hp, or?????<br /><br />This is an USA produced mercury, sold innorway. Not produced in belgium as the most of mercury outboards here.
