Main battery fuses?
MarkNY
hi, id like to use a 50 or 60amp blade fuse to go between my battery and battery switch. i cant find any fuse holders that will handle a fuse that big, most have a 30 amp max. im looking for suggestions on how to handle this fuse setup. thanks alot, mark
bruceb58
Re: Main battery fuses?
You don't put fuses or breakers between your battery and battery switch.
Anything between your battery and starter on your motor is unfused. You need a fuse/breaker between your switch and all the other electrical loads though.
