Main 50 Amp Engine Breaker
Bravo Company
I have a no turn over problem on my 1995<br />3 liter GM Mercruiser setup.<br /><br />The starter is new and will turn the engine<br />over when you apply power directly to the<br />large and small posts with a screwdriver.<br /><br />But when you use the ignition the engine will<br />not turn over. The gauges come on and look good.<br />However when you tun the key all the way the<br />gauges all return to nothing and they will not<br />move again nor will the engine turn over.<br /><br />The only thing that occured was the lanyard<br />switch was off and the boat was turned over<br />several times. Also the big red 50 amp breaker<br />appears to be sticking out further than it used<br />to. Can these be fixed if this is the problem.<br /><br />Replys Welcome thanks.................................
sea wolf
Re: Main 50 Amp Engine Breaker
u probably tripped the breaker when u replaced the starter. reset it & see what happens.
Bravo Company
Hey SeaWolf <br />Thanks.............But if only it was that easy<br />Well maybe it will be ......But the #@$%###*&#<br />breaker looks popped out and it will not<br />reset..................will not push in and<br />I am affraid I will break it.....<br />Come on back................................
medic
Check your ground too.
olddogmike
I would also check the switch and the fuse holder for cracks and corrosion.
If the breaker won't reset, It Proabaly Already Is....<br /><br />Check the switch with a multi-meter... Then work your way to the starter.... That's what the tech will do....
Bravo Company
Thanks for the info.............. <br /><br />There is power to the ignition switch wires.<br />Of the three wires, two appear to have power.<br />However I think there is a short as you<br />have suggested. The reason I think this is because<br />I jiggled wires and fuses at the fuse panel and<br />got the gauges back when the ignition switch was<br />on. But alas no turn over when the ignition<br />was turned all the way to start. <br /><br />Would excessive condensation have destroyed some<br />part of the fuse panel. I sanded all the fuses<br />and all the connections???????????<br /><br />Again thanks so far.................
olddogmike
I have seen the fuse holder terminals corrode and sometimes the plastic will become brittle and the terminals will seperate from the plastic. Water wreaks havon on plastic electrical parts as well as metal. Also, I agree that you should start at the switch and follow the path back to the starter. Check all the switch wire ends for corrosion and separation and deterioration of the wire. Let us know how you make out.
