Maiden Voyage Goes Bad
gregmercer
So I have spent the last 8 Months rebuilding just about everything on my 18' Runabout with a Volvo 230 and SP outdrive.
I put it in the water yesterday, started it up, and everything seemed to be ok. I pulled away from the loading ramp and cruised at idle speed out of the no wake zone. I then tried to give it some gas and it stalled out. I tried doing this a bunch of times and the motor won't rev over 2100 RPMS.
When it is not in gear it will rev high, around 5000 RPMS. But as soon as I put in in gear it spudders and dies at 2100 RPMS......
I do have low compression on the #4 cylinder, its 85lbs where as the rest of the cylinders are 150lbs. I just pulled the head about a week ago, got the head planed because the machine shop said I had a warped head. When I put the head back on it fixed my low compression on cylinder one, but now I have the low compression on cylinder 4. I could also not be timed correctly....
I was hopeing I could just put the boat in the water and cruise around for a couple hours to keep me motivated in this boats rebuild.
What do you guys think the problem is? Could it be the outdrive?
THANKS!!!
Greg
Don S
Re: Maiden Voyage Goes Bad
Get the compression up on the low one and set the dwell and timing, it'll probably run fine.
gregmercer
If I do have a warped block, can that be fixed or must it be replaced?
Greg
Don S
You need to do a leak down test to determine what is actually leaking on #4, BEFORE you take it apart again.
I doubt you have a warped block.
freddyray21
i agree with Don would take a lot to warp a block. get the compression on all cylinders within 10% of each other set the dwell and the timing. If it couldn't be timed something is going on.
