I recently bought two old Johnson 35 HP Seahorse outboards, one is a 1958 with electric start and remote controlled using a wiring harness (RDEL-19), and the other is a 1957 pull start that doesn't use a wiring harness. The '57 motor (RDL-19) was used in fresh water and is in much better condition and therefore I am rebuilding that one, but converting it to electric start with remote controls & wiring harness. The '58 motor with the electric start has only one black wire coming through the bottom of the magneto plate, which connects to the cutout switch and then to the "M" terminal on the ignition switch. However, the '57 pull start motor has 2 black wires coming through the bottom of the magneto plat, one going directly to the cutout switch and the other going to a kill switch that then connects to the cutout switch. My questions are:
1) I swapped out the bottom shroud plate so the engine I'm rebuilding has the correct plate with the wiring plug cast into it and therefore doesn't have a kill switch on the motor, do I completely remove the kill switch and all of its wiring and leave it at that or do I need to run a new black wire from the points/magneto plate to the cutoff switch? and
2) How do both sets of points / coils get connected to the ignition system when the '58 motor only has one black wire going into the magneto plate? Shouldn't it have two wires, one for each set of points / coils. That's how the wiring diagram shows it so I'm confused and need some clarification.
Any insight will be greatly appreciated.
Thanks,
Doug
Thanks,
Doug
