m25c2 question
bigboy799
Hello I have a 1995 25hp tohatsu that had a bad bevel "b"gear .After changing it when I start motor and leave it in neutral and increase rpms it jumps into reverse lower rmps and goes back to neutral.any one have advise.thank you
TOHATSU GURU
Re: m25c2 question
I'm not being flippant, but, take it back apart and this time put it back together correctly. You made a mistake in the assembly this time around.
pvanv
Re: m25c2 question
Yep. Verify the assembly sequence of the push rod, spring holder, shims, etc.
